Ana içeriğe geç
Sony Vaio PCG-4121GL Wifi Board Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: adım 1, 2 resimden 1. Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 2, 3 resimden 1. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 2, 3 resimden 2. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 2, 3 resimden 3.
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 3, 1 resimden 1.
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 4, 3 resimden 1. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 4, 3 resimden 2. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 4, 3 resimden 3.
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: adım 5, 2 resimden 1. Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: adım 5, 2 resimden 2.
    • Lift up the two golden knobs on the left side of the WiFi board.
    • Remove the single 3mm Phillips #0 screw located on the WiFi board to the top left of the battery compartment.
  6. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 6, 2 resimden 1. Sony Vaio PCG-4121GL Wifi Board Replacement: adım 6, 2 resimden 2.
    • Once the screw and the golden knobs have been disconnected, pull the WiFi board out to the left.
    • Once the WiFi board is free from the device, remove completely.
Sonuç
Miguel Camarena
367 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G2, White Winter 2019 Cal Poly, Team S2-G2, White Winter 2019 üyesi
CPSU-WHITE-W19S2G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 573
