Ana içeriğe geç
Sony Vaio PCG-4G1L Keyboard Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-4G1L Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Keyboard Replacement: adım 2, 2 resimden 1. Sony Vaio PCG-4G1L Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Keyboard Replacement: adım 3, 3 resimden 1. Sony Vaio PCG-4G1L Keyboard Replacement: adım 3, 3 resimden 2. Sony Vaio PCG-4G1L Keyboard Replacement: adım 3, 3 resimden 3.
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Keyboard Replacement: adım 5, 2 resimden 1. Sony Vaio PCG-4G1L Keyboard Replacement: adım 5, 2 resimden 2.
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Keyboard Replacement: adım 6, 3 resimden 1. Sony Vaio PCG-4G1L Keyboard Replacement: adım 6, 3 resimden 2. Sony Vaio PCG-4G1L Keyboard Replacement: adım 6, 3 resimden 3.
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cole Collins
175 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Cagle Fall 2016 USF Tampa, Team 2-3, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G3
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 723
