Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn off the computer and disconnect the charging cable.
Slide battery release toggle switch towards the "RELEASE" print.
Apply pressure with your thumb on the grip.
Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
Use the plastic opening tool to release the clamp.
Using slight pressure, remove the ribbon cable with your fingers.
Swivel the Network Antenna up so that it points upward.
Pinch thumb and index finger at the Network Antenna's base.
Pull the Network Antenna off.
Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
Bu adımda kullanılan alet:Tweezers$4.99-
Disconnect the cable by using the precision tweezers.
Slowly pry out the ribbon cable by using the plastic opening tool.
Remove the plastic cover by inserting the plastic opening tool around the edge.
Disconnect the ribbon cable by pulling straight up with your fingers.
Bir başkası bu kılavuzu tamamladı.
