Ana içeriğe geç
Sony Vaio VGN-TXN25N Display Screen Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: adım 1, 2 resimden 1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: adım 1, 2 resimden 2.
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 2, 3 resimden 1. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 2, 3 resimden 2. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 2, 3 resimden 3.
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 3, 2 resimden 2.
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 4, 3 resimden 1. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 4, 3 resimden 2. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 5, 3 resimden 1. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 5, 3 resimden 2. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 5, 3 resimden 3.
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: adım 6, 1 resimden 1.
    • Remove the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Ricker
71 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 üyesi
CPSU-FORTE-S12S5G3
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 3,585
