Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If the LCD Display Screen is black, cracked, or has colored lines running through it when the computer is on, the screen is broken. Follow these instructions on how to install a screen
Parçalar
Hiçbir parça belirtilmedi.
  1. Place the computer on a flat surface with the top facing up. Open the screen.
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Locate the rubber screw caps at the two bottom corners of the screen. Use your finger to remove the rubber screw caps. Use your finger to remove the rubber screw caps.
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Locate the two screws, one on each bottom corner. Unscrew the screws with a Phillips head size #0 screwdriver.
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Use a plastic opening tool to gently lift the plastic casing that borders the screen. Pop off the casing by working the tool around the outside of it. Wiggling the tool may be required. The casing could be fitted snugly.
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Carefully flip down the screen so it rests on the keyboard. Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection. Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Remove the screen.
    • Remove the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Ricker
71 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 üyesi
CPSU-FORTE-S12S5G3
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 3,197
