Ana içeriğe geç
Sony Vaio VGN-TXN25N Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the computer so that the bottom is facing up.
    • Look to the long edge where the computer screen is hinged and find the "release slide". It is located at the top left corner of the square indent.
  2. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 2, 1 resimden 1.
    • Use your finger to slide the release to the left.
  3. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 3, 2 resimden 2.
    • While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide it out.
    Digan me algo esta compu a parte de la batería que muestran ella trae alguna pila redonda pregunto porque tengo un problema con los BIOS y veo que es la única forma de recuperarla
    Pedro Molina - Yanıt
  4. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement, Keyboard: adım 4, 1 resimden 1.
    • Take out the screw in the center of the computer.
  5. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 5, 1 resimden 1.
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  6. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 6, 2 resimden 1. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  7. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 7, 2 resimden 1. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 7, 2 resimden 2.
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  8. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 8, 3 resimden 1. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 8, 3 resimden 2. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 8, 3 resimden 3.
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
  9. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement, Hard Disk Drive: adım 9, 1 resimden 1.
    • Take out the screw under the keyboard.
  10. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 10, 1 resimden 1.
    • Flip computer over and remove the 6 screws.
  11. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 11, 1 resimden 1.
    • Flip computer over again and unclip the plastic cover.
    • Do not be afraid to be rough, since the cover is hard to remove.
    • Be sure to remove the case slowly and unclip any ribbon cords that are attached.
  12. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 12, 2 resimden 1. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 12, 2 resimden 2.
    • Locate the hard drive disk. The hard drive disk will be covered by a shiny lid.
    • Unscrew the lid with a #00 Phillips Head Screwdriver.
    • There are 3 screws holding it in.
    • Grab the lid by one corner and pull off the lid.
  13. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 13, 1 resimden 1.
    • Find the brown clip attached to the hard disk drive on the side facing the optical disk drive.
    • Carefully pull out the brown clip with your fingers.
  14. Sony Vaio VGN-TXN25N Hard Disk Drive Replacement: adım 14, 1 resimden 1.
    • Hold the hard disk drive on the side where the brown clip was attached and lift it upwards to pull it out.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jenny Wang
107 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 üyesi
CPSU-FORTE-S12S5G3
5 Üyeler
12 adet Kılavuz yazıldı
4 Yorum
Muito bom, me ajudou muito...
lordsan32 - Yanıt
Step 10 is actually 7 screws, not 6. There are two screws next to the battery that need to be removed.
Watch out for the ribbon cable in step 11. There are two, one for the trackpad and one for the activity lights. If you have a WWAN card installed, you may have additional coax wires as well. There is also a clip directly below the keyboard ZIF connector and to the left of the trackpad. You will need tweezers to bend it up and out of the way.
I was unable to fully remove the palm rest assembly, but I could flip it over at a 90 degree angle to get the HDD out.
I was able to successfully swap this hard drive with an iFlash mSATA. I used a Transcend 256GB mSATA SSD. I've had bad luck with Dogfish ones, they're cheap garbage and you do not want to take this apart again.
Luciano DiNino - Yanıt
Update the iFlash to mSATA does not work, it makes the optical drive disconnect. That's not acceptable to me, so I will be trying this instead:
Amazon.com: Ximimark 1Pcs Mini PCI-E mSATA to CE ZIF 1.8 inch SSD to 40 pin ZIF CE Cable Adapter Converter Card SSD HDD Adapter Converter : Electronics
The SSD does work and XP was able to install successfully from a flash drive.
Luciano DiNino -
Final update, this worked and the optical drive appears now. Either the ribbon cable in the Vaio is too thin, or the tolerances on this cheap adapter are terrible, but I had to use some electrical tape to force contact. It was too loose otherwise and nothing was being picked up.
The whole thing is upside down in the machine, so you have to carefully bend the ribbon cable for insertion.
All in all, success! Don't buy the iFlash adapter, I think it assigns itself a value (Primary, Secondary, Cable Select) that doesn't play nice with the laptop's IDE controller.
Luciano DiNino -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 16,898
