Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Sony Vaio PCG-4K1L Keyboard Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-4K1L Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Take out the screw in the center of the computer.
  2. Sony Vaio PCG-4K1L Keyboard Replacement: adım 2, 1 resimden 1.
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  3. Sony Vaio PCG-4K1L Keyboard Replacement: adım 3, 2 resimden 1. Sony Vaio PCG-4K1L Keyboard Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  4. Sony Vaio PCG-4K1L Keyboard Replacement: adım 4, 2 resimden 1. Sony Vaio PCG-4K1L Keyboard Replacement: adım 4, 2 resimden 2.
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  5. Sony Vaio PCG-4K1L Keyboard Replacement: adım 5, 3 resimden 1. Sony Vaio PCG-4K1L Keyboard Replacement: adım 5, 3 resimden 2. Sony Vaio PCG-4K1L Keyboard Replacement: adım 5, 3 resimden 3.
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
Sonuç
Austen
32 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 üyesi
CPSU-FORTE-S12S5G3
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 2,077
