Ana içeriğe geç
Sony Vaio VPC-Y2190X Fan Replacement
Neye ihtiyacın var
  1. Sony Vaio VPC-Y2190X Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X Fan Replacement: adım 2, 1 resimden 1.
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X Fan Replacement: adım 3, 2 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 3, 2 resimden 2.
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X Fan Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
    • The screws are held into the panel by washers, they will not fall out once unscrewed.
  5. Sony Vaio VPC-Y2190X Fan Replacement: adım 5, 1 resimden 1.
    • Remove the panel.
    • Use the #0PH screwdriver to remove the four 3.61mm screws.
  6. Sony Vaio VPC-Y2190X Fan Replacement: adım 6, 2 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 6, 2 resimden 2.
    • Carefully lift the hard drive.
    • Remove the hard drive by pulling it to the left.
  7. Sony Vaio VPC-Y2190X Fan Replacement, Fan: adım 7, 1 resimden 1.
    • Remove all nine 5.63mm screws with the #0PH screwdriver.
    • Remove the four 8.62mm screws with the #0PH screwdriver.
  8. Sony Vaio VPC-Y2190X Fan Replacement: adım 8, 3 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 8, 3 resimden 2. Sony Vaio VPC-Y2190X Fan Replacement: adım 8, 3 resimden 3.
    • Flip your Vaio so that the keyboard is facing up.
    • Use the iFixit Opening Tool to lift the keyboard from the frame, starting at the ESC key corner.
    • Gently slide the iFixit Opening Tool along the edge of the keyboard.
    • The keyboard is connected to the frame with a wire, do not fully lift the keyboard from the frame
  9. Sony Vaio VPC-Y2190X Fan Replacement: adım 9, 2 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 9, 2 resimden 2.
    • The cable is located under the keyboard, just above the touchpad.
    • Use the iFixit Opening Tool to flip the clip up in order to release the cable.
    • Detach the cable from the frame.
    • Remove the keyboard from the frame.
  10. Sony Vaio VPC-Y2190X Fan Replacement: adım 10, 3 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 10, 3 resimden 2. Sony Vaio VPC-Y2190X Fan Replacement: adım 10, 3 resimden 3.
    • Use the iFixit Opening Tool to lift the edge of the clip from the cable.
    • Gently pull the cable away from the clip.
    • Repeat the first two steps on the second clip shown in the picture.
  11. Sony Vaio VPC-Y2190X Fan Replacement: adım 11, 2 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 11, 2 resimden 2.
    • Use the iFixit Opening Tool to detach the cable from the motherboard.
    • Use the small needle nose pliers to pull the cable from the motherboard.
  12. Sony Vaio VPC-Y2190X Fan Replacement: adım 12, 3 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 12, 3 resimden 2. Sony Vaio VPC-Y2190X Fan Replacement: adım 12, 3 resimden 3.
    • Use the iFixit Opening Tool to flip the clip up in order to release the first cable.
    • Use the small needle nose pliers to pull the second cable from where it is attached.
    • Use the small needle nose pliers to detach the third cable from motherboard.
  13. Sony Vaio VPC-Y2190X Fan Replacement: adım 13, 2 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 13, 2 resimden 2.
    • Use the iFixit Opening Tool to lift the back of the Vaio from the frame.
    • Slide the iFixit Opening Tool around the edges of the frame.
  14. Sony Vaio VPC-Y2190X Fan Replacement: adım 14, 3 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 14, 3 resimden 2. Sony Vaio VPC-Y2190X Fan Replacement: adım 14, 3 resimden 3.
    • Use the small needle nose pliers to pull the cable connector from the motherboard.
    • Push the flap to the side so you can access the screw beneath.
    • Use the #0PH screwdriver on the one 5.63mm screw.
  15. Sony Vaio VPC-Y2190X Fan Replacement: adım 15, 1 resimden 1.
    • Unscrew the 5.63mm screw tethering the motherboard to the laptop with a #0PH screwdriver.
    • Remove the piece from the motherboard.
  16. Sony Vaio VPC-Y2190X Fan Replacement: adım 16, 3 resimden 1. Sony Vaio VPC-Y2190X Fan Replacement: adım 16, 3 resimden 2. Sony Vaio VPC-Y2190X Fan Replacement: adım 16, 3 resimden 3.
    • Flip the motherboard upside down to access the other side.
    • Use a #0PH screwdriver to remove the three 3.61mm screws holding the fan to the motherboard.
    • Remove the fan from the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 392
