Ana içeriğe geç
Sony Vaio VGN-SR140E RAM Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-SR140E RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E RAM Replacement: adım 2, 1 resimden 1.
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E RAM Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-SR140E RAM Replacement: adım 3, 2 resimden 2.
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E RAM Replacement: adım 5, 2 resimden 1. Sony Vaio VGN-SR140E RAM Replacement: adım 5, 2 resimden 2.
    • Lift the thin black plastic cover to access the RAM.
  6. Sony Vaio VGN-SR140E RAM Replacement: adım 6, 2 resimden 1. Sony Vaio VGN-SR140E RAM Replacement: adım 6, 2 resimden 2.
    • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
  7. Sony Vaio VGN-SR140E RAM Replacement: adım 7, 3 resimden 1. Sony Vaio VGN-SR140E RAM Replacement: adım 7, 3 resimden 2. Sony Vaio VGN-SR140E RAM Replacement: adım 7, 3 resimden 3.
    • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
Sonuç
Jeremy
722 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G6
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 481
