Ana içeriğe geç
Sony Vaio VPCCW17FX Back Case
Neye ihtiyacın var
  1. Sony Vaio VPCCW17FX Back Case, Back case: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Back Case: adım 2, 3 resimden 1. Sony Vaio VPCCW17FX Back Case: adım 2, 3 resimden 2. Sony Vaio VPCCW17FX Back Case: adım 2, 3 resimden 3.
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
  3. Sony Vaio VPCCW17FX Back Case: adım 3, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
  4. Sony Vaio VPCCW17FX Back Case: adım 4, 3 resimden 1. Sony Vaio VPCCW17FX Back Case: adım 4, 3 resimden 2. Sony Vaio VPCCW17FX Back Case: adım 4, 3 resimden 3.
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
  5. Sony Vaio VPCCW17FX Back Case: adım 5, 3 resimden 1. Sony Vaio VPCCW17FX Back Case: adım 5, 3 resimden 2. Sony Vaio VPCCW17FX Back Case: adım 5, 3 resimden 3.
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
  6. Sony Vaio VPCCW17FX Back Case: adım 6, 1 resimden 1.
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
  7. Sony Vaio VPCCW17FX Back Case: adım 7, 1 resimden 1.
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ellie DePorter
310 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 962
