Ana içeriğe geç
Sony Vaio VPCCW17FX LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 2, 1 resimden 1.
    • Slide both latches towards the center of the battery to release.
  3. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 3, 2 resimden 1. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 3, 2 resimden 2.
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 4, 2 resimden 1. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 4, 2 resimden 2.
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 6, 2 resimden 1. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 6, 2 resimden 2.
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 7, 2 resimden 1. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 7, 2 resimden 2.
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. Sony Vaio VPCCW17FX LCD Screen Replacement: adım 8, 1 resimden 1.
    • The screen can now be removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Seowon Song
113 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G5
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 1,093
