Ana içeriğe geç
Giriş
If a specific key on your laptop keyboard is not working, use this guide to help replace the faulty keys on a Sony Vaio PCG-61211L. Sometimes a key can get dislodged causing it not to be registered when typing. Following this guide’s instructions will help fix this problem. It is a very short process that can take 10-15 minutes. All you will need is a pair of tweezers.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use a pair of tweezers like the one shown in the picture.
    • Use a pair of tweezers like the one shown in the picture.
  2. Use the tweezers to get under the key piece on the keyboard as shown in the picture.
    • Use the tweezers to get under the key piece on the keyboard as shown in the picture.
  3. Carefully lift the key piece upward to remove it completely.
    • Carefully lift the key piece upward to remove it completely.
  4. After the key is removed, you should be able to see the part underneath the key where it can be replaced.
    • After the key is removed, you should be able to see the part underneath the key where it can be replaced.
Sonuç
To reassemble your device, follow these instructions carefully in reverse order.
Bir başkası bu kılavuzu tamamladı.
Matt Mersinger
419 İtibar
3 adet Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 346
