Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If a specific key on your laptop keyboard is not working, use this guide to help replace the faulty keys on a Sony Vaio PCG-61211L. Sometimes a key can get dislodged causing it not to be registered when typing. Following this guide’s instructions will help fix this problem. It is a very short process that can take 10-15 minutes. All you will need is a pair of tweezers.
Neye ihtiyacın var
To reassemble your device, follow these instructions carefully in reverse order.
Bir başkası bu kılavuzu tamamladı.
