Ana içeriğe geç
Sony Vaio PCG-61411L Optical Disc Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: adım 1, 3 resimden 1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: adım 1, 3 resimden 2. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 2, 3 resimden 1. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 2, 3 resimden 2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 2, 3 resimden 3.
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 4, 2 resimden 1. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 4, 2 resimden 2.
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 5, 3 resimden 1. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 5, 3 resimden 2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 5, 3 resimden 3.
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 6, 3 resimden 1. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 6, 3 resimden 2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 6, 3 resimden 3.
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
  7. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: adım 7, 2 resimden 1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: adım 7, 2 resimden 2.
    • Remove the 5mm screws with the PH0 screwdriver.
    • Remove the 3mm screws with the PH0 screwdriver.
  8. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 8, 2 resimden 1. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 8, 2 resimden 2.
    • Lift the backplate from bottom right and left corner and remove it from the laptop.
  9. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 9, 2 resimden 1. Sony Vaio PCG-61411L Optical Disc Drive Replacement: adım 9, 2 resimden 2.
    • Slide your finger from the right of the optical disc and pull the optical disc from right to left.
Sonuç
Patrick Jean Baptiste
214 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 UMass Dartmouth, Team S2-G1, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 574
