Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
Slide the "release" switch to the left and gently lift the battery up to remove it.
Completely remove the battery from the device.
The hard drive panel is located in the bottom right corner of the device.
Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
Remove the panel by pulling it up towards yourself.
Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
Carefully remove the silver hard drive cover.
Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
Remove the 5mm screws with the PH0 screwdriver.
Remove the 3mm screws with the PH0 screwdriver.
Lift the backplate from bottom right and left corner and remove it from the laptop.
Slide your finger from the right of the optical disc and pull the optical disc from right to left.
