Ana içeriğe geç
Sony Vaio PCG-61411L RAM Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Sony Vaio PCG-61411L RAM Replacement, Battery: adım 1, 3 resimden 1. Sony Vaio PCG-61411L RAM Replacement, Battery: adım 1, 3 resimden 2. Sony Vaio PCG-61411L RAM Replacement, Battery: adım 1, 3 resimden 3.
      • Be sure to disconnect the device charger and power down the device before beginning.
      • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio PCG-61411L RAM Replacement: adım 2, 3 resimden 1. Sony Vaio PCG-61411L RAM Replacement: adım 2, 3 resimden 2. Sony Vaio PCG-61411L RAM Replacement: adım 2, 3 resimden 3.
      • Slide the "release" switch to the left and gently lift the battery up to remove it.
      • Completely remove the battery from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Vaio PCG-61411L RAM Replacement, RAM: adım 3, 1 resimden 1.
      • The RAM cards reside in the rectangle shaped plate in the center of the back panel of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio PCG-61411L RAM Replacement: adım 4, 2 resimden 1. Sony Vaio PCG-61411L RAM Replacement: adım 4, 2 resimden 2.
      • Unscrew the single PH1 6mm screw at the top of the panel. The screw remains in the panel.
      • Remove the panel by lifting it towards yourself.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio PCG-61411L RAM Replacement: adım 5, 3 resimden 1. Sony Vaio PCG-61411L RAM Replacement: adım 5, 3 resimden 2. Sony Vaio PCG-61411L RAM Replacement: adım 5, 3 resimden 3.
      • To remove the individual RAM card panels, snap back the metal latches on each side of the cards.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Vaio PCG-61411L RAM Replacement: adım 6, 2 resimden 1. Sony Vaio PCG-61411L RAM Replacement: adım 6, 2 resimden 2.
      • After pinching the metal latches, the RAM card should pop out slightly upward.
      • Remove the cards by pulling them out to the left.
      • Repeat for the second panel of RAM cards.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sean Lyon
381 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 UMass Dartmouth, Team S2-G1, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G1
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 1,443
