Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
RAM acts as the temporary memory for your device. RAM can become damaged, or more RAM may be needed to accomplish arduous tasks. This guide will demonstrate how to remove and replace your RAM.
Parçalar
Hiçbir parça belirtilmedi.
  1. Be sure to  disconnect the device charger and power down the device before beginning. Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right. Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Slide the  "release" switch to the left  and gently lift the battery up to remove it. Completely remove the battery from the device. Completely remove the battery from the device.
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Manta Tornavida Seti
    112 bits for every fix.
    Upgrade Your Toolbox
  4. The RAM cards reside in the rectangle shaped plate in the center of the back panel of the device.
    • The RAM cards reside in the rectangle shaped plate in the center of the back panel of the device.
  5. Unscrew the single PH1  6mm screw at the top of the panel. The screw remains in the panel. Remove the panel by lifting it towards yourself.
    • Unscrew the single PH1 6mm screw at the top of the panel. The screw remains in the panel.
    • Remove the panel by lifting it towards yourself.
  6. To remove the individual RAM  card panels,  snap back the metal latches on each side of the cards. To remove the individual RAM  card panels,  snap back the metal latches on each side of the cards. To remove the individual RAM  card panels,  snap back the metal latches on each side of the cards.
    • To remove the individual RAM card panels, snap back the metal latches on each side of the cards.
  7. After pinching the metal latches, the RAM card should pop out slightly upward. Remove the cards by pulling them out to the left.
    • After pinching the metal latches, the RAM card should pop out slightly upward.
    • Remove the cards by pulling them out to the left.
    • Repeat for the second panel of RAM cards.
Sonuç
Sean Lyon
378 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 UMass Dartmouth, Team S2-G1, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 510
