Giriş
Through the use of this guide, you will be able to successfully remove the RAM from a Sony Vaio PCG-61A14L Laptop. Please see pre-requisite guides in order to aid in your replacement efforts. The RAM will need to be replaced if the laptop runs exceptionally slow or programs unexpectedly crash. Ensure that the RAM is the SO-DIMM standard. Be careful to push back the pins holding the RAM in place. The RAM should move when these pins are moved correctly.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
