Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the laptop so the bottom is facing up with the model number visible.
Slide the lock switch down until you hear a click to unlock the battery.
Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
Loosen the two (7mm) screws that hold the hard drive panel in place with a JIS #0 screwdriver.
Remove the plastic and unscrew the screw on the hard drive using the JIS #0 screwdriver.
Push the hard drive towards the optical reader to unlock it.
After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
Remove the single screw holding the panel in place using the JIS #0 screwdriver.
Remove the green circuit board by dislodging the circuit it is attached to.
Unhook it and remove it from the device.
Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
