Ana içeriğe geç
Sony Vaio VPCEG26FX Fan Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCEG26FX Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Sony Vaio VPCEG26FX Fan Replacement: adım 2, 2 resimden 1. Sony Vaio VPCEG26FX Fan Replacement: adım 2, 2 resimden 2.
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Sony Vaio VPCEG26FX Fan Replacement: adım 3, 2 resimden 1. Sony Vaio VPCEG26FX Fan Replacement: adım 3, 2 resimden 2.
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Sony Vaio VPCEG26FX Fan Replacement: adım 4, 2 resimden 1. Sony Vaio VPCEG26FX Fan Replacement: adım 4, 2 resimden 2.
    • Remove the battery from the battery compartment.
  5. Sony Vaio VPCEG26FX Fan Replacement, Back Panel: adım 5, 1 resimden 1.
    • Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
  6. Sony Vaio VPCEG26FX Fan Replacement: adım 6, 2 resimden 1. Sony Vaio VPCEG26FX Fan Replacement: adım 6, 2 resimden 2.
    • Remove the back panel from the device.
  7. Sony Vaio VPCEG26FX Fan Replacement, Fan: adım 7, 1 resimden 1.
    • Remove the three 7mm screws attached to the fan using the JIS #0 screwdriver.
  8. Sony Vaio VPCEG26FX Fan Replacement: adım 8, 3 resimden 1. Sony Vaio VPCEG26FX Fan Replacement: adım 8, 3 resimden 2. Sony Vaio VPCEG26FX Fan Replacement: adım 8, 3 resimden 3.
    • Unplug and remove the Fan.
Sonuç
Sara Alfaro
531 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, Botvin Spring 2019 UMass Dartmouth, Team S1-G4, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 419
