Neye ihtiyacın var
Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
Once the cover has been loosened, pry the cover with your finger for it to come off.
#1 Unscrew the back panel
#2 Then work the tool around the sides to release cover. You may need a second tool to help keep your loose corner open.
3 farklı kişi bu kılavuzu tamamladı.
