Ana içeriğe geç
Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement
  1. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement: adım 2, 1 resimden 1.
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement: adım 3, 1 resimden 1.
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Sonuç
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
4 farklı kişi bu kılavuzu tamamladı.
Brian Luu
720 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G17
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
How to test my battery performance Sony VAIO
Pcg- 7184L
Ramesh C - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 3,251
