Giriş
The battery of the Vaio PCG-7184L is on the underside on the laptop. The removal of the battery is an important step that should be taken for any other repair, displacement, or dis-assembly.
  1. Power off the laptop.
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Locate two switches above the battery that lock it into place.
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  4. Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Sonuç
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
Bir başkası bu kılavuzu tamamladı.
Brian Luu
561 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G17
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
How to test my battery performance Sony VAIO
Pcg- 7184L
Ramesh C - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 6
Son 30 Gün: 27
Her zaman: 2,250
