Giriş
This guide will assist with the replacement of the Sony Vaio PCG-7184L's optical drive. Please review the Troubleshooting Guide before replacing your optical drive.
Parçalar
Hiçbir parçaya gerek yok.
  1. Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Grip the cover of the optical drive and slide it out.
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin McGowan
572 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G17
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 5
Her zaman: 1,234
