Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will assist with the replacement of the Sony Vaio PCG-7184L's optical drive. Please review the Troubleshooting Guide before replacing your optical drive.
Parçalar
Hiçbir parça belirtilmedi.
  1. Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  2. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  3. Grip the cover of the optical drive and slide it out.
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin McGowan
605 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G17
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 1,407
