Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Lay the closed laptop on its screen so the bottom is facing towards you.
Revome the battery by pushing it away from the laptop.
Set the battery away from the laptop.
Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
Slide the cover until it is free from the laptop case.
Lift the cover to remove.
Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
The Hard Drive should now be disconnected.
Lift the drive out with the tab on the tray.
2 farklı kişi bu kılavuzu tamamladı.
