Ana içeriğe geç
Giriş
This guide helps users remove the plastic panel that covers the RAM compartment of the Sony Vaio PCG-7A2L laptop.
Parçalar
Hiçbir parça belirtilmedi.
  1. Lay the closed laptop on its screen so the bottom is facing towards you.
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Push both latches towards the center of the battery.
    • Push both latches towards the center of the battery.
  3. Revome the battery by pushing it away from the laptop. Set the battery away from the laptop.
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. With the bottom of the laptop facing up, locate the RAM cover. The RAM is covered by the panel with four columns of vents.
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters) Once the panel is out of its locked position, it can be lifted out without any resistance. Once the panel is out of its locked position, it can be lifted out without any resistance.
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
Sonuç
Brian Marchini
269 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G32
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 7
Her zaman: 4,460
