Ana içeriğe geç
Sony Vaio VPCF115FM Back Panel Assembly Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Battery: adım 1, 2 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so the bottom is facing up.
  2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 2, 3 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 2, 3 resimden 2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 2, 3 resimden 3.
    • Unlock the left tab on the battery.
    • Glide the right battery tab to release the battery pack from the laptop.
    • Keeping the battery tab in the released position, lift the battery up.
  3. Sony Vaio VPCF115FM Back Panel Assembly Replacement, RAM: adım 3, 2 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, RAM: adım 3, 2 resimden 2.
    • Remove the 9mm Phillips #1 screw located on the back cover.
    • Remove cover.
    • Push out metal tabs.
    • Remove card.
  4. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove two 9mm Phillips #1 screws.
  5. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 5, 3 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 5, 3 resimden 2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 5, 3 resimden 3.
    • Remove the panel.
    • Gently remove the hard drive.
    • Remove screws securing caddy to hard drive.
  6. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Disk Drive: adım 6, 2 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Disk Drive: adım 6, 2 resimden 2.
    • Remove the 9mm Phillips #1 screw holding the disk drive in place.
    • Remove the 9mm screw near the memory stick.
  7. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 7, 1 resimden 1.
    • Using an iFixit opening tool, carefully pry the disk drive away from the device.
  8. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Back Panel Assembly: adım 8, 2 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Back Panel Assembly: adım 8, 2 resimden 2.
    • Remove three 3mm Phillips #1 screws on the side panel.
  9. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 9, 3 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 9, 3 resimden 2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 9, 3 resimden 3.
    • On the top of the panel, remove four 3mm Phillips #1 screws.
  10. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 10, 1 resimden 1.
    • Remove the rest of the twelve 9mm Phillips #1 screws on the back panel.
    • Remove the final screw.
  11. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 11, 3 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 11, 3 resimden 2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 11, 3 resimden 3.
    • Using an iFixit opening tool, pry the back panel off.
    • At this point, the back panel should very easily pop off.
    • Be careful around mechanical components on the edges of the laptop (audio output, USB ports).
  12. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 12, 3 resimden 1. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 12, 3 resimden 2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: adım 12, 3 resimden 3.
    • Continue popping the back panel off.
    • The back panel should now be off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Haylie Hotte
638 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G6, Peak Spring 2019 UMass Dartmouth, Team S6-G6, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G6
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
The fan ran at high speed and the laptop would randomly shut down. I suspected a cooling problem. Turned out there was a layer of dust caked on the “fan side” of the cooling fins. I removed the fan/heat sink assembly and used a vacuum and an artist’s brush to clean the fins and fan blades. Put a fresh layer of thermal compound on the CPU and GPU heat sinks and reassembled everything. This back panel removal/replacement instruction page was a great help. Everything went back together successfully and, to my amazement, there were no screws left over!
Wil Higdon - Yanıt
Ganhei um Sony Vaio PCG-81114L usado porem nao tem os parafusos (todos) e nao estou encontrado aqui no Brasil. Tem como ajudar? O procedimento esta 10 e é bem simples. My email: joaocastelor@hotmail.com
joaocastelor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,714
