Giriş
The main objective of this guide is to show the easiest way to remove the back panel. This guide will focus mainly on removing the screws along the back panel.
Neye ihtiyacın var
Remove the 9mm Phillips #1 screw located on the back cover.
Remove cover.
Push out metal tabs.
Remove card.
Remove the 9mm Phillips #1 screw holding the disk drive in place.
Remove the 9mm screw near the memory stick.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
The fan ran at high speed and the laptop would randomly shut down. I suspected a cooling problem. Turned out there was a layer of dust caked on the “fan side” of the cooling fins. I removed the fan/heat sink assembly and used a vacuum and an artist’s brush to clean the fins and fan blades. Put a fresh layer of thermal compound on the CPU and GPU heat sinks and reassembled everything. This back panel removal/replacement instruction page was a great help. Everything went back together successfully and, to my amazement, there were no screws left over!
Ganhei um Sony Vaio PCG-81114L usado porem nao tem os parafusos (todos) e nao estou encontrado aqui no Brasil. Tem como ajudar? O procedimento esta 10 e é bem simples. My email: joaocastelor@hotmail.com
