Ana içeriğe geç
Giriş
If you are experiencing trouble with your optical drive, you may need to use this guide in order to replace it. This is a beginner level process. There is no background knowledge or special requirements you need in order to successfully replace your optical drive.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the first of two screws located at the marker in the photo.
    • Remove the first of two screws located at the marker in the photo.
  2. Remove the second of the two screws located at the marker in the photo.
    • Remove the second of the two screws located at the marker in the photo.
  3. Grab and slide out the tray from the side of the laptop after both screws have been removed.
    • Grab and slide out the tray from the side of the laptop after both screws have been removed.
  4. Slide in new CD drive and repeat steps 2 and 1 in reverse to screw the new drive down.
    • Slide in new CD drive and repeat steps 2 and 1 in reverse to screw the new drive down.
Sonuç
Alejandro Lopez
305 İtibar
2 adet Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 318
