Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Rotate the device 90° counterclockwise until the battery cover is in front of you.
The battery cover is located in the lower right side of the device in this new orientation.
Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
In this new orientation, the battery cover is located on the left side.
To remove the battery cover, use your hands to slide it upwards.
Now, the battery should be completely removed from the device.
