Giriş
Wonder why your computer runs slow and your fan is on all the time? Well, this is due to improper use or your computer. The fan is an important component in your system because it helps your device to stay at normal temperatures.
Neye ihtiyacın var
Turn the laptop off and unplug it.
Remove the screw on the left-hand side of the computer towards the back using a small Phillips #0 screwdriver.
Open the laptop with the screen facing you.
Carefully lift the left side of the panel and unhook the right side. Do not pull beyond the length of the ribbon cable that secures it to the motherboard.
To separate the ribbon cable from the motherboard, grip it near the base and gently pull.
There are two speakers on the underside of the speaker panel, one on each end. Unplug both sets of the black and red wires from the circuit board by gently pulling at the base.
Remove the screws (two per speaker) with the Phillips #0 screwdriver. Then remove the metal brackets holding the speakers in place.
Remove the adhesive tape securing the speaker wires to the panel.
This picture is a top view of the computer after the speakers and keyboard have been removed.
