Ana içeriğe geç
Sony Vaio PCG-981L Floppy Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-981L Floppy Drive Replacement, Floppy Drive: adım 1, 1 resimden 1.
    • Turn the device over so that its underside is facing up. Then, slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
  2. Sony Vaio PCG-981L Floppy Drive Replacement: adım 2, 1 resimden 1.
    • Remove the floppy drive from the laptop.
  3. Sony Vaio PCG-981L Floppy Drive Replacement: adım 3, 1 resimden 1.
    • There are two screws on each side of the floppy drive (four screws total). Remove these screws.
  4. Sony Vaio PCG-981L Floppy Drive Replacement: adım 4, 1 resimden 1.
    • Remove the floppy drive core from its casing.
  5. Sony Vaio PCG-981L Floppy Drive Replacement: adım 5, 1 resimden 1.
    • Unscrew the five screws from the back of the optical drive.
  6. Sony Vaio PCG-981L Floppy Drive Replacement: adım 6, 1 resimden 1.
    • Remove the two screws holding part of the floppy processing unit.
  7. Sony Vaio PCG-981L Floppy Drive Replacement: adım 7, 1 resimden 1.
    • Remove the entire floppy drive processing unit.
  8. Sony Vaio PCG-981L Floppy Drive Replacement: adım 8, 1 resimden 1.
    • Here is an isolated image of the core hardware of the floppy drive. This is where the floppy "magic" happens. Check for any connection failures or shortages. You may need to resolder some of the connections.
  9. Sony Vaio PCG-981L Floppy Drive Replacement: adım 9, 1 resimden 1.
    • Here is an isolated image of the floppy drive casing unit.
Sonuç
Loratious
10 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-68, Johann Spring 2010 Cal Poly, Team 18-68, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G68
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 2,721
