Giriş
If for any reason the floppy drive isn't working, the simplest solution is to replace the entire drive. But, if you're not able to aquire a new drive you may be able at least find the source of the failure through disassebling the drive.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Turn the copmuter over so that its underside is facing up. Then slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
Neredeyse bitti!
Sonuç
