Giriş
This guide will show you how to release the optical drive. There are a variation of screws that need to be removed before you can release the optical drive by sliding it out. Please read the instructions while using the pictures for reference.
Neye ihtiyacın var
Position the laptop screen-side down as shown.
In this position the battery housing will be located on the right hand side.
There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
Remove the three screws surrounding the fan.
Take off the guard that you just unscrewed.
Carefully flip over the heat pipe and the metal sheet connected to it.
