Ana içeriğe geç
Sony Vaio PCG-F420 RAM Replacement
Neye ihtiyacın var
  1. Sony Vaio PCG-F420 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
  2. Sony Vaio PCG-F420 RAM Replacement: adım 2, 1 resimden 1.
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
  3. Sony Vaio PCG-F420 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Remove the screw holding the RAM cover down.
  4. Sony Vaio PCG-F420 RAM Replacement: adım 4, 1 resimden 1.
    • Use a spudger to lift the covering, revealing the RAM modules inside the computer.
  5. Sony Vaio PCG-F420 RAM Replacement: adım 5, 1 resimden 1.
    • To remove the RAM currently inside the computer, gently pull out the white tabs on each side of the RAM module.
    • The RAM will pop up at an angle where it can be pulled out without damaging the socket.
    • Remove the RAM module by pulling at the same angle the RAM is at.
  6. Sony Vaio PCG-F420 RAM Replacement: adım 6, 1 resimden 1.
    • To insert the new RAM module, match the notch in the middle of the gold edge of the RAM to the notch in the laptop.
    • Insert the RAM at the same angle the other module came out at and make sure the end of the ram is actually in the slot. Gently push down on the RAM until it clicks in.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Therin Irwin
22 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G77
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 2,291
