Ana içeriğe geç
Sony Vaio Pro 13 Internal Battery Replacement
Neye ihtiyacın var
  1. Sony Vaio Pro 13 Internal Battery Replacement, Bottom Cover: adım 1, 2 resimden 1. Sony Vaio Pro 13 Internal Battery Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Sony Vaio Pro 13 Internal Battery Replacement: adım 2, 2 resimden 1. Sony Vaio Pro 13 Internal Battery Replacement: adım 2, 2 resimden 2.
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Sony Vaio Pro 13 Internal Battery Replacement: adım 3, 2 resimden 1. Sony Vaio Pro 13 Internal Battery Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
  4. Sony Vaio Pro 13 Internal Battery Replacement, Internal Battery: adım 4, 1 resimden 1.
    • Once the bottom cover is removed, peel away the piece of tape located near the fan and heat sink assembly.
  5. Sony Vaio Pro 13 Internal Battery Replacement: adım 5, 2 resimden 1. Sony Vaio Pro 13 Internal Battery Replacement: adım 5, 2 resimden 2.
    • Remove the three 4.2mm Philips #0 screws located at the top of the battery.
    • Simply lift the battery away from the computer.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Alex R
1.005 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
I need help my Sony vaio pro 13 svp132a1cm. the power button light is dim and charging light is on but it won’t turn on I have tried everything if any one can help that will be great
Hasnain - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 82
Her zaman: 25,285
