Ana içeriğe geç
Sony Vaio Pro 13 Trackpad Replacement
Neye ihtiyacın var
    1. Sony Vaio Pro 13 Trackpad Replacement, Bottom Cover: adım 1, 2 resimden 1. Sony Vaio Pro 13 Trackpad Replacement, Bottom Cover: adım 1, 2 resimden 2.
      • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
      • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio Pro 13 Trackpad Replacement: adım 2, 2 resimden 1. Sony Vaio Pro 13 Trackpad Replacement: adım 2, 2 resimden 2.
      • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
      • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio Pro 13 Trackpad Replacement: adım 3, 2 resimden 1. Sony Vaio Pro 13 Trackpad Replacement: adım 3, 2 resimden 2.
      • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
      • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Vaio Pro 13 Trackpad Replacement, Internal Battery: adım 4, 1 resimden 1.
      • Once the bottom cover is removed, peel away the piece of tape located near the fan and heat sink assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio Pro 13 Trackpad Replacement: adım 5, 2 resimden 1. Sony Vaio Pro 13 Trackpad Replacement: adım 5, 2 resimden 2.
      • Remove the three 4.2mm Philips #0 screws located at the top of the battery.
      • Simply lift the battery away from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Vaio Pro 13 Trackpad Replacement, Trackpad: adım 6, 2 resimden 1. Sony Vaio Pro 13 Trackpad Replacement, Trackpad: adım 6, 2 resimden 2.
      • Use the nylon spudger to lift up on both of the white wire strips.
      • Then use your fingers to lift them up.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio Pro 13 Trackpad Replacement: adım 7, 2 resimden 1. Sony Vaio Pro 13 Trackpad Replacement: adım 7, 2 resimden 2.
      • Using the Phillips head screwdriver, remove the four screws holding the track pad in.
      • Use the Phillips head again and remove the final black screw.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio Pro 13 Trackpad Replacement: adım 8, 2 resimden 1. Sony Vaio Pro 13 Trackpad Replacement: adım 8, 2 resimden 2.
      • Finally, remove the track pad from the computer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex R
1.005 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
I still have my old Sony Vaio pro, the track pad has been sticky recently and I've used this guide to take it apart and clean it. Very very helpful!! Happy to put off buying a new laptop for a bit longer, thank you :)
Emily Sabin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 4,391
