Giriş
Trackpad replacement
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
Remove the two rubber feet at the back of the computer, these can be removed in the same way.
Once the bottom cover is removed, peel away the piece of tape located near the fan and heat sink assembly.
Use the nylon spudger to lift up on both of the white wire strips.
Then use your fingers to lift them up.
Bir başkası bu kılavuzu tamamladı.
