Giriş
The removal of the WiFi card is very simple for even the least tech savvy people. The only tools necessary are a plastic opening tool such as a spudger and a Phillips #00 screwdriver. Once these tools are obtained, the steps are very easy to follow.
Neye ihtiyacın var
Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
Remove the two rubber feet at the back of the computer, these can be removed in the same way.
Remove the black tape from on top of the WiFi card.
Use the spudger to remove the white wire from the WiFi card.
Bir başkası bu kılavuzu tamamladı.
