Giriş
This guide shows how to remove the screen of a Sony Vaio SVE111B11L. This repair may be needed if the screen melts or cracks. To replace the screen follow the guide in reverse order.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Locate the battery on the bottom of the computer.
Flip the computer so that the battery faces you.
Remove the memory door on the bottom of the computer to access the screw for the keyboard.
Locate screws. L 3.35mm X D 1.8mm
Remove Screws.
Lay the screen on a hard flat surface.
Remove hinges and wires for ease of removal.
Bir başkası bu kılavuzu tamamladı.
