Aletler
Parçalar
Hiçbir parça belirtilmedi.
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the battery on the bottom of the computer.
Flip the computer so that the battery faces you.
Locate the two latches with the words “lock” and “release” on them.
Push the latches towards each other and lift the battery to remove it.
Remove the memory door on the bottom of the computer to access the screw for the keyboard.
Remove the 6.7 mm screw that holds the keyboard assembly in place.
Slide the wires out, away from the solder connections.
Flip the computer over and open it.
Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
Using an opening tool, gently pull out and slightly up on the connector clip.
Gently lift the keyboard assembly up and out.
Locate and remove the screws holding the motherboard down.
Screws: L 4.6mm X D 1.85mm
Locate the wires and connectors.
Unplug any connectors that are interfering with the removal of the motherboard.
Gently lift the mother board out, being careful of the loose connectors and wires
Locate screws. L 3.35mm X D 1.8mm
Remove Screws.
Lay the screen on a hard flat surface.
Remove hinges and wires for ease of removal.
Gently remove the screen cover.
Be careful of the camera at the top of the screen.
Be careful of the seal tape between the cover and the screen.
Unplug the wires from the connectors.
Be careful of the yellow tape around the connection.
Bir başkası bu kılavuzu tamamladı.
