Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the battery on the bottom of the computer.
Flip the computer so that the battery faces you.
Locate the two latches with the words “lock” and “release” on them.
Push the latches towards each other and lift the battery to remove it.
Remove the memory door on the bottom of the computer to access the screw for the keyboard.
Remove the 6.7 mm screw that holds the keyboard assembly in place.
Slide the wires out, away from the solder connections.
Flip the computer over and open it.
Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
Using an opening tool, gently pull out and slightly up on the connector clip.
Gently lift the keyboard assembly up and out.
Locate the wires and connectors, and gently unplug them.
Locate and remove the 6.7 mm screws that hold the fan assembly.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
There are missing steps. For example - after removing keyboard assembly, there are 4 screws under it.
Keyboard assembly is not ment to be removed in way showed in pictures. There are melted plastic tabs to keep top cover in place. By prying that, you will broke them and top cover will not be possible to put back as before.
Only keyboard itself should be removed by prying it out, starting from bottom (thoucpad). Top of keyboard has larger “ears“ and they are hooked under top cover.
