Ana içeriğe geç
Sony Vaio SVE111B11L Keyboard Assembly Replacement
Neye ihtiyacın var
  1. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: adım 1, 2 resimden 1. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Keyboard Assembly Replacement: adım 2, 1 resimden 1.
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Keyboard Assembly Replacement: adım 3, 1 resimden 1.
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Keyboard Assembly: adım 4, 1 resimden 1.
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Keyboard Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Keyboard Assembly Replacement: adım 6, 1 resimden 1.
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Keyboard Assembly Replacement: adım 7, 3 resimden 1. Sony Vaio SVE111B11L Keyboard Assembly Replacement: adım 7, 3 resimden 2. Sony Vaio SVE111B11L Keyboard Assembly Replacement: adım 7, 3 resimden 3.
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
John Noll
777 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,167
