Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector. Locate the battery on the bottom of the computer.
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Locate the two latches with the words “lock” and “release” on them.
    • Locate the two latches with the words “lock” and “release” on them.
  3. Push the latches towards each other and lift the battery to remove it.
    • Push the latches towards each other and lift the battery to remove it.
  4. Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
    Incorrect picture for this step. Is should show removing the main cover on the bottom of the laptop to reveal the memory and hard drive
    Steve - Yanıt
  5. Remove the 6.7 mm screw that holds the keyboard assembly in place.
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Be careful not to break the keyboard wire connection.
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
    Not sure what wires I'm supposed to slide out. Again, picture is no help.
    Steve - Yanıt
  7. Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches. Using an opening tool, gently pull out and slightly up on the connector clip. Gently lift the keyboard assembly up and out.
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
    I found that it was easier to remove the keyboard starting from the front edge (away from the screen) because the clips are shorter on this side. The only problem is that the cable is at the front so you have more danger of breaking it. Again, the picture is incorrect - don't try to remove the panel around the keyboard as shown, just go for the central keyboard unit.
    Steve - Yanıt
  8. Locate the fan and heat-sink.
    • Locate the fan and heat-sink.
  9. Locate the wires and connectors, and gently unplug them.
    • Locate the wires and connectors, and gently unplug them.
  10. Locate and remove the 6.7 mm screws that hold the fan assembly.
    • Locate and remove the 6.7 mm screws that hold the fan assembly.
  11. Gently lift the fan assembly up and out.
    • Gently lift the fan assembly up and out.
  12. Remove charging adaptor. Some charge may still be in the battery or computer.
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers over the motherboard off.
  13. Locate and remove the screws holding the motherboard down.
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  14. Locate the wires and connectors. Unplug any connectors that are interfering with the removal of the motherboard. Unplug any connectors that are interfering with the removal of the motherboard.
    • Locate the wires and connectors.
    • Unplug any connectors that are interfering with the removal of the motherboard.
  15. Gently lift the mother board out, being careful of the loose connectors and wires Gently lift the mother board out, being careful of the loose connectors and wires
    • Gently lift the mother board out, being careful of the loose connectors and wires
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Noll
777 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
i have the same laptop, and i mistakenly remove the mother board cmos battery , and is not recognizing my laptop system hard drive.
in this case what can i do in other to restore it back.
onyebuchiadieze - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 1,464
