Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the battery on the bottom of the computer.
Flip the computer so that the battery faces you.
Locate the two latches with the words “lock” and “release” on them.
Push the latches towards each other and lift the battery to remove it.
Remove the memory door on the bottom of the computer to access the screw for the keyboard.
Remove the 6.7 mm screw that holds the keyboard assembly in place.
Slide the wires out, away from the solder connections.
Flip the computer over and open it.
Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
Using an opening tool, gently pull out and slightly up on the connector clip.
Gently lift the keyboard assembly up and out.
Locate the wires and connectors, and gently unplug them.
Locate and remove the 6.7 mm screws that hold the fan assembly.
Locate and remove the screws holding the motherboard down.
Screws: L 4.6mm X D 1.85mm
Locate the wires and connectors and remove them from the motherboard.
Lift the mother board out and safely put it to the side.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
i have the same laptop, and i mistakenly remove the mother board cmos battery , and is not recognizing my laptop system hard drive.
in this case what can i do in other to restore it back.
