Ana içeriğe geç
Sony Vaio SVE15112FXS Hard Drive Replacement
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: adım 3, 2 resimden 1. Sony Vaio SVE15112FXS Hard Drive Replacement: adım 3, 2 resimden 2.
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: adım 4, 1 resimden 1.
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: adım 5, 2 resimden 1. Sony Vaio SVE15112FXS Hard Drive Replacement: adım 5, 2 resimden 2.
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: adım 6, 2 resimden 1. Sony Vaio SVE15112FXS Hard Drive Replacement: adım 6, 2 resimden 2.
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashley Bierman
1.196 İtibar
5 adet Kılavuz yazıldı
Ohio State, Team S1-G1, Whitney Fall 2018 Ohio State, Team S1-G1, Whitney Fall 2018 üyesi
OSU-WHITNEY-F18S1G1
2 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 515
