Ana içeriğe geç
Sony Vaio SVE15112FXS LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Vaio SVE15112FXS LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 2, 3 resimden 1. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 2, 3 resimden 2. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 2, 3 resimden 3.
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  3. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 3, 1 resimden 1.
    • Turn the computer back over and open the lid.
    • Remove the four rubber screw covers at each corner of the screen to expose the bezel screws
  4. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 4, 1 resimden 1.
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screen bezel screws in each corner.
  5. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 5, 2 resimden 1. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening tool between the bezel and laptop lid. Work it around the edge to loosen the bezel.
    • Lift the bezel outward to remove it and expose the screen.
    • Take care when using the spudger near the hinges to avoid breaking the bezel.
  6. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 6, 2 resimden 1. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 6, 2 resimden 2.
    • Use a #0 Phillips screwdriver to remove the four 3.0 mm screen screws.
    • Cover the keyboard with a cloth or towel to protect the screen and keep any broken glass out of the keyboard.
  7. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 7, 3 resimden 1. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 7, 3 resimden 2. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 7, 3 resimden 3.
    • Pull the screen toward you and away from the lid until a silver cable behind the screen is visible.
    • Remove the silver cable from the back of the screen. It is glued at the top and the bottom.
    • Do not pull the cable loose from the lid, only remove it from the back of the screen.
  8. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 8, 3 resimden 1. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 8, 3 resimden 2. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 8, 3 resimden 3.
    • Lift the barcode label on the back of the screen upward to loosen the screen cable connector.
    • Once the connector is visible, remove it from the pins on the back of the screen.
  9. Sony Vaio SVE15112FXS LCD Screen Replacement: adım 9, 1 resimden 1.
    • Lift the screen toward you to remove it completely from the lid.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashley Bierman
1.301 İtibar
5 adet Kılavuz yazıldı
Ekip
Ohio State, Team S1-G1, Whitney Fall 2018 Ohio State, Team S1-G1, Whitney Fall 2018 üyesi
OSU-WHITNEY-F18S1G1
2 Üyeler
11 adet Kılavuz yazıldı
1Rehber Yorum
How to buy the screen.my screen has gone...
PCG21212w 19.5V Sony vaio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 34
Her zaman: 1,220
