Ana içeriğe geç
Giriş
The Hard Disk Drive is responsible for storing your data. This is a comprehensive guide for replacing the HDD (Hard Disk Drive).
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip laptop over so the bottom is facing upwards.
    • Flip laptop over so the bottom is facing upwards.
  2. Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
    • Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
  3. Pop open the cover to the HDD. Pop open the cover to the HDD.
    • Pop open the cover to the HDD.
  4. Remove the  screws on the HDD with a Phillips #000 screwdriver.
    • Remove the screws on the HDD with a Phillips #000 screwdriver.
  5. Pull plastic tab away from the laptop. Lift HDD away from laptop.
    • Pull plastic tab away from the laptop.
    • Lift HDD away from laptop.
Sonuç
Alex Theg
683 İtibar
4 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 UMass Dartmouth, Team S9-G9, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S9G9
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 530
