Ana içeriğe geç
Giriş
The speakers allow the laptop to play sounds such as music. This guide shows the steps to remove the speakers for repair or replacement.
  1. Turn the laptop over so its underside is facing upwards and visible.
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Standing so that the barcode and warning labels are upright and legible,  push the left tab up and away from yourself.
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Standing so that the barcode and warning labels are upright and legible,  push the right tab up and away from yourself.
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Pull battery away from laptop.
    • Pull battery away from laptop.
  6. Flip laptop over so the bottom is facing upwards.
    • Flip laptop over so the bottom is facing upwards.
  7. Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
    • Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
  8. Pop open the cover to the HDD. Pop open the cover to the HDD.
    • Pop open the cover to the HDD.
  9. Remove the  screws on the HDD with a Phillips #000 screwdriver.
    • Remove the screws on the HDD with a Phillips #000 screwdriver.
  10. Pull plastic tab away from the laptop. Lift HDD away from laptop.
    • Pull plastic tab away from the laptop.
    • Lift HDD away from laptop.
  11. Remove the back cover. Remove the back cover. Remove the back cover.
    • Remove the back cover.
  12. Remove 4 hinge screws  with a Phillips #0 screwdriver. Remove 4 hinge screws  with a Phillips #0 screwdriver.
    • Remove 4 hinge screws with a Phillips #0 screwdriver.
  13. Pop open hinge. Remove black screw size P000. Remove black screw size P000.
    • Pop open hinge.
    • Remove black screw size P000.
  14. Remove wiring along its guide. Remove wiring along its guide.
    • Remove wiring along its guide.
  15. Remove two hinge screws size P00. Pop open hinge. Pop open hinge.
    • Remove two hinge screws size P00.
    • Pop open hinge.
  16. Remove black screw. Remove black screw.
    • Remove black screw.
  17. Remove secondary black screw. Remove secondary black screw.
    • Remove secondary black screw.
  18. Remove speaker.
    • Remove speaker.
  19. Follow wire down its wire channel and remove it from the channel. Pull up on the connector to disconnect the speakers to the motherboard.
    • Follow wire down its wire channel and remove it from the channel.
    • Pull up on the connector to disconnect the speakers to the motherboard.
  20. Remove speaker and wire from the laptop.
    • Remove speaker and wire from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Theg
683 İtibar
4 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 UMass Dartmouth, Team S9-G9, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S9G9
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 194
